My first overclock
Possibly yes if you bought a decent 80mm fan that had a good air flow rating, but tidying up your cables definately would help the airflow.... also try and set your fans up so that they maintain a steady flow throught the case rather than just pushing hot air around the case
I will tidy up the cables when i put my other hd in, the fans at them moment i have 4
1x on the font sucking in air
2x on the rear blowing out air
1x suspended over the memory using cable ties to keep it cool.
So i will look at my temps after cable tidying, and if needs bew add anither silent 60mm fan somewhere or buy a 80mm fan and adapter to keep my cpu temp around 40-45 load. The pc has been on for 3 hours half an hour prime, installing new software running 3d mark 03 twice and 3d mark 05, and my current cpu temp is 27.
Does that seems ok?
