You want to be running the prime95 torture test, it just keeps on going. Stepping stones time wise are 1 hour, 2 hour, 6 hour, 12 hour, 24 hour.Mark A said:ran prime 95 its passed all 5 tests twice so i assume its prime stable?.
Not really, I seen Prime/Orthos error out quite a bit after 3 hours. I've seen Prime run 'blend' perfectly for 12 hours and then go and fail 'large-FFTs' after 6.IceShock said:somtimes it can take over 24hours for it to find a error but if it doesnt up to 3 hours its normally stable
Everyone had their own definition of what is 'stable', as a rule of thumb I would say throw anything and everything at your PC, go out of your way to provoke it to crash, run Prime/Orthos in the background and then start looping 3DMark, throw a 32MB Super-PI in their, OCCT etc.
. I have been doing the torture test, i think its the mixed one that tests a bit of everything.
, this cooler is rubbish (Akasa Evo33) i think i need a bigger fan than the 80mm fan on this.
, looks like 250 will have to do.
