- 29 Feb 2012
- London
What graphics are you using in this system?
Nice one redek, looking good, what multi are you on and at what voltage?
What thermal paste did you use on the cpu cooler and how much did you put on?
Ive been trying to remember what thermal paste I used. I think it might have been the one that came with the i5 stock cooler.
Pretty sure I applied the right amount too.
paste which is supplied with the stock cooler is pre applied to the base of the cooler, still think you can get those temps down more so maybe worth getting some decent paste.
Stulid did a nice review of loads of different ones, have a read here http://forums.overclockers.co.uk/showthread.php?t=18416534
Cheers very much.
Just checked again in the bios and multiplier is 42, voltage 1.84 and ram voltage 1.55 (although both voltages flicker about a tiny bit)
1.84 vcore on your CPU?
does that voltage sound about normal?
Redek is 1.84 your vcore/cpu voltage, if so what are you using to cool? Chilled water? Ln2? Normal-NO.
