My First 'Spec me' £350 MAX, basic system please
11 Oct 2005
Derbyshire
Hi, looking to build a basic system.
Requirements are as follows.
HTPC Size case. So was thinking Antec Fusion Case £140 from ocuk
The rest is as follows. (So I am thinking)
i3 CPU
4GB RAM
250 GB HD (Min)
DVD re-writer
Need Wireless card
6 USB ports
Would be nice if motherboard had DVI as that is what my monitor has
Also, would at times like to connect it to a big LCD/Plasma TV to watch media.
So perhaps a Graphics card suitable for that with HDMI
Audio, I know motherboards come with the 'jack plugs' for the speakers. But would be nice if it had optical out in case I want to go that route sometime.
Main use of computer will be:
Surfing internet
Watching Videos
Admin Work
Photos
No gaming.
£350 Max. I already have a new OS ready to install (Windows 7)
Many thanks if anyone can advise me.
£357 with free delivery
• Sandybridge based Celeron CPU, low power usage and heat.
• Motherboard has,
http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dh67bl.html
Two Serial ATA 6.0 Gb/s ports
Three Serial ATA 3.0 Gb/s ports, with one port compatible with eSATA extension
One eSATA 3.0 Gb/s port
Two USB 3.0 ports
Fourteen USB 2.0 ports, six back panel ports and eight additional ports via four internal headers
DVI-I and HDMI* connectors for processors with Intel® HD Graphics
10-channel (7.1+ 2 independent multi-streaming) audio subsystem using the Realtek ALC892* audio codec
Five analog audio ports and one optical S/PDIF out port
Internal S/PDIF header and front panel audio header
Heres with a i3,
Pull out the PSU that comes with the case, chuck it in the bin, use the GX450.
quick question.
Just got all this delivered today. The motherboard just came in a bag with I/O Plate, disc and 1xsata cable. Never knew that, thought it would be box'd
anyhow. As there is no manual, which slots do I put the 2 sticks of RAM Memory (as above) in. Blue or Black, or does it not matter as long as both in the same colour slots.
quick question.
power supply question to motherboard. it has a square 4 pin socket on motherboard and a 24 long socket. I know in the past I have used a 20 plug and then a 4 plug in another socket (the one NOT near the long 20 pin socket)
the PSU (as listed above) has a 20 plug with another 4 plug attached to it and then also on one of the psu cables I have 2 4 plug sockets. Do I need to use the 4 plug if I use a 24?
thanks
