rite had a bit of a slow day today,F1,shopping ect for wife lol,so not done much finished cabling off only just got the fan controller to do and connect all the fans up,shouldnt be long now hopefully.so here's a pic of my cable management,maybe not the best in the world but its the best i have ever done.
my next job is to connect the sensors to the cpu and fans,now whats the best way to approach applying these sticky sensors,where should they go,instuctions are not great and dont say much about where they should go
also im working on a little something,it may work or it might not,but without giving it ago who know's.so the plan is this here's a pic as i know you love pics lol.
basically the drives are hidden behind the fans,so there's no cables to be seen which is my plan to hide as much of cables as possible.you can get to the drives from going through the front panel and slide them out that way,so there still moveable if needed.
the fans will be blowing over the mobo keeping the cpu,gpu cooler,same as my rad theroy we have done so far and that is working well,so why not try it from this angle as well and see if it will reduce the temps anymore,might work or it wont lets see.
if it does work i will be getting some fans that brad found for me that match the case colour perfectly,so will replace them to adda bit more colour inside.
this is another pic of inside so far,think i have hidden cables pretty well so far,pitty about the dvd drive but wont be seen when door is on anyway.
