Will look into the fiat airbox, thanks
Right, things didnt exactly go to plan with the welding today
I cut a plate out for the area that needed reapair
Marked all the areas that needed to be welded
We thought we'd try TIG welding it to try and minimise any sparks etc that would fly about and land on the bodywork and it looks tidier. It didnt work, lots of seam sealer still in the seams that cant be removed but caused havoc with the welding arc. Welder is going to come back on the weekend and blast it with a MIG.
Managed to secure the battery tray and weld some clean seams, but then we ran out of gas!
Nothing seems to be going to plan at the moment, I even managed to bang my head on one of the Konis that was hanging up in the garge!
Can't refit anything until it's painted!
Can't paint it until it's welded!
Can't do anything to the engine until a cambelt tensioner thats on back order arrives in 7-10 days from Germany....
Plus the deadline for finishing might be 6 weeks from now dependant on how something goes next Monday which I cant mention at the moment.
Argh!
Going to create a to do list and take it from there I think!
Argh!
one today, should be here tomorrow!
