My Golf Project
  • Thread starter Thread starter L1J
  • Start date Start date
I had to upgrade my Photobucket account yesterday, it's just hosting the pics on this thread and done 9.5GB in 3 weeks!
Started to rub down under the bonnet this morning, got to here
Will finish rubbing it down over the next two days and hopefully get it sprayed at the end of the week.
Carried on rubbing down and started to clean the engine bay
Example of an awkward place that needs to be prepared prior to painting
Left it soaking in degreaser will be continued tomorrow.
Berger said:
Hmm that parts degreaser tub thing looks interesting!
Any pictures of that out the box! :)
Will sort some out for you tomorrow
Lopéz said:
Parts washers are well handy.
Yup, we have one in work very useful. Need to order some degreaser for mine, hard to find decent stuff these days, everything seems to be environmentally friendly and less effective!
Mini update
More stuff has arrived from bilthamber, from left to right rust converter, rust killer and wax
The wax came with an applicator
Which has 4 sets of holes at 90 degrees apart on the nozzle to spray it everywhere!
Need to get the rust from these hubs
So made a Deox bath and left them
You chuck 'em in the boxything and spray them with the washing liquid (degreaser, not fairy liquid :p). Never used the one we have at home though, so I'm just guessing that's what you do...along with things like using wirebrushes etc.
InvG
You fill the tub with degreaser then switch the pump on which constantly recirculates degreaser through the nozzle on to your parts. Use a brush of some kind to agitate whatever your trying to clean!
I hate using the degreaser at work, it's all I can taste afterwards and it tends to get everywhere when using the clean air line to dry the parts :(
Not much done today
Gearbox before
Used this, which I got today :D Much easier than elbow grease!
Ended up like this
Hubs are looking much better after a soaking in the deox bath, need a few more hours I think
Little update
Springs after they were powder coated
Tab for throttle cable bracket welded on to inlet manifold, will be taken to be powder coated along with some other bits soon
Need to carry on with the paint prep tonight, hopefully it will be sprayed with primer over the weekend.
EDIT
challengedavid said:
You should have waited 1 minute :D
You have more toys than me! No fair! :( :( :(
The bath looks good, what solution have you used with it?
I normally just use gunk+brush lots! :o
