My Golf Project
  • Thread starter Thread starter L1J
  • Start date Start date
mark66 said:
What is a Proportioning Valve? Does it allow you to alter the brake bias?
As said by everyone else, yes it does. I'm going to use it on the rear brake line, it will allow me to change the amount of pressure that reaches the rear brakes.
I'm determined to keep the Golf as standard looking as possible so I didnt want the bias valve on show. As mentioned in my last post the bias valve was going to be insatlled where the manual choke would be.
Dash was already out, so made this a lot easier! Rear of where the choke would be located:
Bracket cut and bent out of the way, dash cut slightly to allow the knob to pass through
Dash brace modified to mount bias valve on to it
Valve in position with some fabricated alloy brackets
Following this very keenly, some fantastic work you're doing mate, I'd never have the motivation!
L1J said:
...allow the knob to pass through...
Is it really bad that I sniggered at that? How juvenile :D
Faithless said:
Yum! What paint are you using on the calipers my good man?
Halfords High Temp Engine Paint, it's Satin Black I think. Matches the powder coating I had done nicely.
Caliper has come up well, I spent an hour on prep before painting!
How did you find the paint was it the spray on stuff?
I did my crossover tubes and intake in it lastnight (Red) and it fingerprints like mad!
Lopéz said:
Tool arrived dude, I recognised the handwriting :p - cheers, it's a whopper!
Bet you can't break it :p
It was the brush on stuff.
My usual prep routine is:
Degrease
Give it a good going over with the grinder wire brush attachment to remove any rust etc
Give it a clean with panel wipe
Paint
By finger prints do you mean the paint creases? What material are your cross pipes and did you use primer?
Didn't explain myself very well, primed / sprayed / dryed overnight, but since the finish is very matt and has no overcoat it picks up... say i have a little bit of oil on my hands it picks that up and sticks like mad, can you buy high temp laquer?
Same here it does tend to show dirt, I havent seen any high temp laquer about. I can't see your cross pipes getting *that* hot so normal laquer might be ok?
The temperature tolerance of normal laquer is amazingly high. It would certainly be ok for most hot applications (rocker covers et al)
Thanks for the info L1J - contemplating giving my calipers a spring clean and paint but might stick with some hammerite stuff.
Funny you should say that, I've just given the calipers a second coat with hammerite. The finish on the high temp stuff was too matt on the calipers. Will post some pics later.
Update:
Calipers painted in hammerite satin black as mentioned in the previous post
Painted under the scuttle panel, much of this is hidden under lots of plastic covers etc so it was painted black.
Was told off for putting a dirty windscreen bottle back on the car by Dad (the most messy person ever!) :rolleyes: so here it is soaking in bleach :D
lol @ your dad... he has a point though! :) why spoil a spotless finish with something like that? :)
surprised you havent made a stainelss steel one! :)
looking ver ygood though... cant wait to see it with the motor in and wheels on.
