My Hard drive revamp.
Permabanned
26 Oct 2004
Isle of Wight
So I've recently gone from a Kingston 128GB V-Series to a Crucial C300 128GB for my OS drive, and from an old Maxtor 250GB to a WD 500GB (WD500AAKS).
I went for the WD because I could pick it up for the right money locally, and in the hope that it might be fairly reliable over say a Samsung F1/F3 1TB, which would have been the alternative.
I think I'm rather happy with the improvements, and hopefully my findings may help some others looking to do something similar;
think i'd have gone for the drive that has faster write speeds an maybe suffer a slightly lower read speed if it was a matter of funds, however if u have the funds then you could get the Crucial RealSSD C300 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC256MAG-1G1)
that has better write speeds without suffering any loss on the read speeds, it's also double the capacity
nice setup, try to avoid the 006 firmware on the c300 drive if you can, there are a few reports of the drive freezing in games and windows applications.
but apparently turning off write buffer fixes it for now.
im using the c300 64gb with 2 sammy spinpoints 500gbs good setup so far.
I didn't realise there were firmware updates for the C300. Thanks for the heads up though, I guess I'll wait for the next version before giving it a go. Do you know if a new version is expected any time soon?
I spent a long time considering the Vertex 2 vs. C300. I have very little need for super fast write speeds, certainly not to the extent where an extra 100MB/s over what I already achieve is going to make any discernible difference. Where as the higher read speeds are likely to be much more useful.
The 256GB was more than I was willing to spend.
