Ok, first off this is my first time on a forum so please be nice
I have seen some pretty amazing builds on here which will make mine look terrible in comparison lol, but the whole point of mine is that I had a very limited budget. I am recycling everything I can from my 5 year old build and buying mainly used components, whilst still getting a nice looking, quiet PC capable of playing the latest games (well thats the idea anyway).
In 2008 I bought a PC from an ebay company called "pallicom". Huge mistake, the case will cut off your arm if you're not careful and the PSU blew up (literally, I swear there was a flame) within 5 months.
So here is my current PC
Look how tidy and clean it is!
Also, my hard drives were making funny noises and getting very hot so I had to do this :
Unfortunately I can't afford a new CPU, MOBO and RAM so the plan is to keep the CPU, RAM and MOBO and upgrade everything else. I can then overclock the CPU to 3.4ish which hopefully shouldn't bottleneck anything else.
So I will be keeping my:
q6700 (currently at 2.4GHz)
abit IP35 (I don't like it much but it does the job)
8gb ram (not really enough for the video editing I do but its the max my MOBO supports)
And here's the bits i've ordered so far:
Asus GTX570 - £120 from gumtree
HAF X - £80 - eBay
Thermalright Silver Arrow - £65 - overclockers
PSU - XFX 750w XXX edition - £85 - overclockers (Should be ok if I want to add another 570)
So total spent is £350 (not bad at all seeing as with new components and a gtx670 it would have been £600ish and only 20% or so faster)
Hopefully my case and PSU should last a long time, if I find that my graphics card isn't enough (i'm running a 2650*1440 monitor) then I can always SLI. I'm also planning to water-cool when haswell comes out, if I can save up for long enough
I'll see when I get it, but I think I will be modding the side panel on the HAF X to remove the fan and put in a bigger piece of perpex. Also, does anyone have any tips on lighting? I have seen cold cathodes and LED's but I'm not really sure which ones to go for?
HAF X - £80 - eBay
Sorry :/
Can't wait to get a proper case
, I would most probably invest in a heatpipe tower cooler if your budget permits it, or go with a cpu water loop from Corsair. For a tower cooler I would recommend a Cooler Master Hyper 212 Evo.
