Cheap and cheerful CPU cooling would be an arctic 7 cooler - very quiet and very cheap.
I was thinking about that one, but in the end I went for the thermalright silver arrow. A bit expensive, but it should allow me to get the same sort of overclock as a H100, plus they seem to hold there value quite well so I shouldn't loose much when I upgrade to proper watercoolingI would recommend a Cooler Master Hyper 212 Evo.
I was thinking about that one, but in the end I went for the thermalright silver arrow. A bit expensive, but it should allow me to get the same sort of overclock as a H100, plus they seem to hold there value quite well so I shouldn't loose much when I upgrade to proper watercooling![]()
I really don't know what happened :/ I think the power connecter must have been forced downwards by the bundle of cables at the back of the case. Nothing a bit of glue can't fix thoughUnlucky turn with that drive, did the connector just snap off?
I'm actually very happy performance wiseremember performance first
