finally got this little project sorted after bits been sat idle until I was well enough to finish it,still needs some wires tidying up and mouse and kb wires re routing when I feel upto it.
asus 1070 dual,i5 6400,2x 240gb ssds,420 radiator and magicool v2 pump,bykski water blocks
its basically made inside the desk and the whole lot sildes out on rails like a drawer with radiator on front,so I can do any tinkering with the whole lot on the desk still running
its covered internally with black neoprene and looks really cool close up
temps are mid 20's at idle and under 40 running benchmarks and ive finally managed to get a decent overclock on the 1070
I used a pcie extension ribbon from liheat..works perfect with zero performance drop.
