My infamous SBS 2008 brings more issues! :D
20 Aug 2007
Solihull
Hey guys, the sbs server is giving me a headache again, adding client computers back onto the domain under the instruction of my MD. Had an issue where the client pc's were saying there was an issue with something not being up to maximum requirements, I found out this was easily fixed by a server update.
This isn't a MAJOR issue but it is annoying however, even though the clients are definitely online and connected to the server, the SBS console shows them as offline or unknown, does anyone know as to why? :(
If it won't let you disable the firewall you just need to tweak the group policy settings to remove the block.
This obviously shouldn't be necessary. What OS are the clients running?
Its a DNS issue if the clients are showing as Offline or Unknown on the Console.
Can you ping the clients by Hostname from the server?
Rob
Had to make sure the ipv4 settings were point specifically at the SBS server on 192.168.10.2 and I had to go into advanced, "append dns suffix" and put in the dns address of my server, i.e. myserver.local
