My 9800X3D Jonsbo D41 build
18 Oct 2002
London
Hi OcUK,
This is nothing special, just a bog standard build. I just wanted a place to archive my build log.
It's in a Jonsbo D41 Black with Screen:
Smart little case, I think I bought last one OCUK had in stock.
Specs:
AMD Ryzen 7 9800X3D (Pre-ordered)
32GB KLEVV CRAS V DDR5 6400Mhz CL32
Gigabyte X870E Aorus Elite WIFI7
Arctic Freezer III 360 ARGB
Seasonic 760 Platinum PSU
China Special PSU extension cables
Jonsbo D41
GPU Pending
6 Fans Pending (Lian Li Uni SL wireless maybe)
What's currently arrived:
Awaiting:
Hopefully wave 1
This is a temp card until 5080 releases, currently on back order, ordered @£399.99. Will happily wait, or cancel if too close to 5080 release. My GTX1070 will have to hang on to life support for a few more months
what are you going to have on the screen?
looks like your existing setup is under the desk so what will you see?
I got the d31 which it quite nice, a little flimsy when you take all the panels off. What's the argd plan?
Yeah, 100% agree, it does flex a bit when panels are off, nothing special in build quality.
It is basically a £65 when bought without the screen, it is not bad but nowhere near high end stuff i used to before.
RGB Plan: OFF! I bought RGB cos i wanted a black/grey theme, and RGB is on sometimes to impress my nieces and nephews when they come around
nah, its on the desk far right
i don't know what i'm gonna put on the screen. People put custom dashboards with AIDA64.
I see my motherboard has a front HDMI out, so might as well have a screen
You can turn it on for Xmas!
The D31 is my son's, he has a a320 with no headers so I need to buy a controller. I fear he is going to use some garish flashing lights. There are a lot of nice features like the recessed motherboard.
It’s a smart little case, very small considering what it can hold.
It was to be a stop gap case before the Phanteks Evolv X2 releases but it has grown on me.
