A full setup I have no interest in, a ATCS840 will easily accommodate a full system.
Always had an eye on those Corsair/Antec things, but keep getting put of by various stuff such as noisy/buzzing/rattling pumps, poor performance and a few other little annoyances that I see some people say.
if you decide to play with lucid virtu can you let me know how you get on, i had epic fail when i tried.
The left is a P2350H the right is a 2433bw
i didnt realise how to set it up properly, had a play and now it seems to be ok. what i dont get is how obv is better at encoding that 2xHD6850s
Hey Stulid,
Just a few curious questions:
- When you setup your Z68 motherboard, do you have a lead from one of the onboard graphics sockets connected to your TFT as well as your discrete graphics card?
- Do you have to switch your TFT from say HDMI 1 to HDMI 2 or DVI as examples depending on which connectors your using?
So say your going to watch a film, all the power juice just comes from the Intel Onboard graphics?
Cheers,
Because the onboard Intel graphics should use a lot less power when watching films, even using youtube. My 6950 fan increases quite abit when doing either of these.paradisiac said:why do you want to connect it via both to 1 monitor?
Infact I will connect my Energy Monitor, to see how much power draw the 6950 uses when watching youtube / films.
Will report back . . . .
Cool, I'm not sure how it works but would like to use everything desktop wise for the Intel onboard and obviously games with discrete.paradisiac said:i will plug my tv into the onboard hdmi and the monitor into the gfx dvi and see if both will work when i get home if you like. see if its clever enough to run both.
Thought I would suck the GPU's hot air out with my hot box.
