meansizzler said:Cause they think they look good, case there cheap?, cuase they like the super price annoying lights?...
Raikiri said:Don't like the case but looks fairly tidy inside.
My PC7:
Thorpy said:Cases like that are not nice at all.
Yewen has taste in cases.
Nix said:Which one don't you like? Your PC-7 or the OP's case?
BTW, where's your filter / 120mm, etc?
Mr Mister said:Crafty camera angleSo we cant see the wires eh?
mosfet said:Dustiest. GTX. Evar.![]()
Raikiri said:What do you think? -_-
...whats the point on a rear fan?
Neon said:are you serious?
the rear fan extracts the hot air and im sure your case temps would drop seriously, common pc knowledge tbh!
Raikiri said:Are you serious?
Whats the point of a FILTER on a rear fan, it just stops 50% of the airflow and causes noise
In case you havent noticed I have had this case a while, temps have risen about 1-2c since removing it and I have a quieter replacement on the way... I do know what I am doing.
Oh and look, my northbridge fan is unplugged and it isnt a passive heatsink! Oh noes... long as it is stable and quiet I couldnt care less.
