- 10 Aug 2011
I upgraded my CPU and motherboard. Since than, I had PC restart on me and crash. But I had no BSOD.
What could be the problem? If I don't get BSOD does that mean the hardware is working properly and that the drivers are the ones causing it to crash?
Here is my PC spec
CPU: AMD FX 8350 4.0Ghz
Memeory: 8GB corsair DDR3
GPU: AMD HD 6870
Motherboard: ASUS M5A97 R2.0
Samsung SSD 128GB and 500GB Wester Digital.
PSU: XFX(Seasonic) 600W
OS: Windows 7 64bit
This what happened. I was on eBay and my PC restarted. There weren't any programs running in the background, except Avast and AMD Catalyst. When my PC booted to Windows, it did not say my PC recovered from a serious error. But later I realized I did not update the BIOS and that my PC was running on outdated BIOS which did not support AMD 8350 Piledriver. I presume this what caused my PC to restart, but I'm not too sure.
Even after the BIOS update, my PC randomly crashed when I was watching Youtube video. Once again, I only had Avast and AMD Catalyst running in the background. I tried hitting Ctrl+Alt and Delete and nothing happened. I pressed the reset button and I was able to boot in to Windows.
I have tried the following test:
Memtest, ran it for 4 hours and no errors.
Prime95 64Bit --1 hour, no warnings or errors.
Burn-in test -- Pass. No fail.
I have updated all the hotfix from AMDs website for AMD Piledriver.
Could the crashing be related to the drivers? I never got ANY BSOD. Even under stress test, it passed without crashing.
I installed Windows after upgrading and re-installed it after updating the BIOS
Any thoughts?
Cheers for any help, guys n' girls.
Here is my PC spec
GPU: AMD HD 6870
OS: Windows 7 64bit
Any thoughts?
