I have now almost finished my initial overclock - just one last piece of advice need.
My components are
Asus A8N-E
Athlon64 3700+ (SD)
Geil Value RAM (2 x 1GB)
Arctic Freezer 64 Pro
This is how it is currntly running
CPU - 270 x 10 = 2.7GHz (voltage = stock)
RAM - 225MHz (333 divider) - timings 2.5-3-3-7 1T (voltage = 2.65)
HyperThread - 3x = 810MHz
The CPU will go higher but I'm going to leave it for a while - not sure MoBo will do much above 270 anyway from what I've read.
My question is about HyperThreading. I've got the multi on x3 (810) at the moment. I could put it on x4 (1080) but I'm not sure how high above 1000 you can go.
(i) Do you think 1080 is okay for HT
(ii) Is it safe to just try it or is there a danger of permanent damage
(iii) What about running at 810 - does it matter - what impact is it likely to have.
Cheers,
Nigel
My components are
Asus A8N-E
Athlon64 3700+ (SD)
Cheers,
Nigel
