Hello and Welcome to my Parvum Systems Case Build
In in the Final stages of getting all the parts Needed to start this build
Energy Saving & Space is My Motto for this Build!
Will be using Tubing 10/8mm making more space in the Case & better airflow. small ID tubing/hose will do just as well than larger ID
I have Frosted Green panels with USB 3.0 already fitted on the way from (Parvum - Thanks Justin & the rest), frosted green go well with the motherboard -G1-Sniper M3
Hardware to be added to the Build
Gigabyte Z77-G1-Sniper M3 Intel Z77 (Socket 1155) DDR3 MicroATX Motherboard
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail (Energy Saving) also no CPU fan will be used (Energy Saving)
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit
Gigabyte ATI Radeon HD 7970 Windforce 3X GV-R797OC-3GD
VTX3D HD 7970 GHZ X-Edition 3072MB
Creative Sound Blaster Z High Performance Gaming Sound Card - OEM
Corsair AX860w ATX '80 Plus Platinum' Modular Power Supply (Energy Saving) (Saving Space)
Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache
Intel 520 Series 180GB 2.5" SATA 6Gb/s Solid State Hard Drive (Energy Saving)
Samsung SE-506BB/TSBD External BluRay-RW / DVD-RW Drive - Black (Retail) (Saving Space & Energy)
XSPC EX240 Crossflow Radiator (Saving Space)
XSPC RayStorm CPU WaterBlock for (Intel) & (AMD)
2 x Watercool Heatkiller GPU-X ³ 79X0 (Saving Space)
EK-D5 X-RES 100 CSQ - Acetal
XSPC D5 Vario Pump upto 1500 rpm
Masterkleer Tubing UV Active Green Tubing 10/8mm (5/16 ID) (Saving Space)
EK-VGA I/O bracket for HD 7970 Graphics Card (Saving Space)
NZXT Sentry LXE Touch Screen External Fan Controller (Saving Space inside Case)
Phobya Flexible Thread Funnel - Black G 1/4
G1/4in Fillport - Delrin
New hardware in Pictures...
