Hey man. Great build. Hoping to get myself one of these cases very soon.
What did the do with the tubing coming out of the top radiator? Does it go back around the side of the radiator, towards the front of the case, or does it go through to the compartment in the back of the case?
jeez a single 240 running 2 7970's and a 3570k? Good luck with that
Hi, Nope its a XSPC EX240 Crossflow Radiator ,this means there is 1 g1/4 Port: hole each end of the radiator saves you use tube/hose & also makes a tidy build
