My Pc Desk Build (Pic Heavy)
31 Jul 2014
Loughborough
Now Named! Project VORTEX!
[Edit]
Thought id add a rough list of things left to do!
Radiator side of desk
Fill and sand ready for paint
Paint
Route fan cable neatly to rear center compartment
Route Uv cold cathode cables to rear center section
Install sound proofing
Install gasket for door
Install gasket for top
Install Uv cold cathodes
Install white led directional lights
Install hinges for top
Install Actuator for top(unconfirmed)
Power/Filter side of desk
Design and build a filter panel
Install ducting for intake
Make a tray to house all the control gear for the fan and various electronics
Make Hdd tray
Wiring
Wiring
Wiring lol
Finnish making the door
Fill and sand
Paint
Gasket for top
Install actuator for top(unconfirmed)
Install hinge for top
Pump/Resi Section
Route and the cabling through
Mount the pumps
Cut appatures for PSU
Install PSU
Finnish plumbing up pumps and resi's
Install leak detection
Soundproof(based on db levels)
Gasket for top
Component section
Decide on components
Work out cable routing holes
Cut said holes
Make GPU mounting bracket
Make SSD mounting brackets
Resleeve miles of cables
Install Uv lighting
Install back lighting
Finnish plumbing
Decide on finnish for aluminium panels
Finnish backlit logo
Gasket for top
Paint
Desk top
Cut Oak top to size
Cut window appature for component section
Cut appature for instrument panel
Cut window appature for radiator(unconfirmed)
Sand with like 10000grit sand paper to get super smooth :)
Finnish in protective coating
So first off let me say a little about me, im 28 from leicestershire, im an electrician by trade but ive been tinkering with computers since i was young.
Ive been using OcUk for my last maybe 4 builds so approx 10 years but only really thought recently to share this project with the forum!
I feel i need to give you a bit of background on how my pc building/modding has progressed over the years to get me to this point so here goes....
Leading up to me starting work at 16 we just had your run of the mill family pc's like many out there, and after starting work and having money coming in i decided i wanted a pc of my own that would be better at running the games i was playing at the time.
My first custom built pc was around 2004 it was pretty basic, ordered all the parts from OcUk and even back then their customer services were impecable! :p The parts came a day or two later and away i went putting it together, from memory it had a core2duo, 8gig ram, a maximus formula board and 2x 8800gtx's all ran in a nice black case(which i cant remember the make) on air cooling.
The next build i got a bit more adventurous, this was around 2007 from memory, i decided to try watercooling! i picked a nice case and modified the top to take a 360 rad, painted the inside matt black and the outside in a cool chamo scheme. This build had i think a q6600 cpu, cant remember the board or ram but i sandwiched a 4870x2 in there(huge card for the case id chosen!) I enjoyed this pc for a few years but the construction and modding were a bit amateur lol
The next build and my current one i went the next step, i decided on twin cooling loops and a hell of a lot more modding! This one ive actually got a few pics :) I wont explain much about this build as the threads designed for the next build ;) but ill let the pics speak for themselves!
I started with a huge Lian-li A70FB case and went to town!
The specs...
I7 2600k
Asus p8Z68 v Pro mobo
16gb kingston Hyper X grey ram
2x His 6970 IceQ Turbos
So now coming up to the new build! My current pc is getting a bit tired and ive recently bought my first house so i was in need to two things!
1. A new Pc desk as unfortunately i cant take the one i was using to the new place
2. Pc upgrade! :cool:
So that got me to thinking, why not combine the two and make the whole desk the pc!
Great! so i had the idea and me being me if i redo ANYTHING the next version has to be bigger and better than the old one! ;) I needed to work a few things out, so i got to scribbling a few ideas down and worked a few dimension issues out and i had some basic ideas,No google sketchups here just random scribbles on what ever's at hand!
I wanted the desk to look like a nice piece of furniture as well as a kick ass pc so convieniently it helps my brother builds high end kitchens at work! So after securing some nice beech plywood i started knocking something together!
Also at this point id like to point out i dont have access to any woodworking or engineering equipment so all the work has mainly carried out with basic power tools and by hand, oh and lots of fettling (buzz word for this build lol)
So some pics so far...
Making the sides to the side cabinets
One done! I then made a duplicate for the other side and realised the sides looked rather plain, to i grabbed a trimmer thingy off my brother with a tapered cutter and cut some grooves to make the sides look like tounge and groove paneling!
I think that came out quite nice :) I then made the centre section that will house the components!
Chair in there to check i fit under the thing! lol
Thanks for viewing! :)
FaNaTiiCz
So back from dinner heres some more!
I made some standoffs for the component tray and back panel (all a bit rough at the mo, ready for tweaking later!)
And filled a few screw holes ready for sanding
FaNaTiiCz
Bit more :)
5mm Aluminium tray in the bottom for the components and 2mm Aluminium for the sides, i did kinda cheat here and get the local metal merchants to cut them to the rough sizes just because i didnt have and tools that would do it easilly!
Trying out a logo design on the back panel
And a move artistic view :)
FaNaTiiCz
Now for some juicy bits, now that ive got all the space i could need i though i better get some serious cooling potential! What better than the Mo-Ra 360 LT! One of the biggest radiators on the market!
First off i had to make a hole for all the air to pass through
Then out of 5mm Acrylic i fasioned a mounting bracket/plate
Sealed both parts with 3mm sticky back glazing tape
Now any plasterers or boarders out there may realise ive made this standoff bracket out of a length of steel partition frame! Another freebie :)
Now with a radiator this size handling this much water i needed to move a lot of air, and with it being mounted so far from the psu (approx 1.4m!) wiring in 9x 120mm fans just wasnt going to cut it, so i opted for something different!
Thats a 12" 80w dc car radiator fan! should do the trick! :)
I then made another mounting plate to fit the fan to, another stand off frame to give the fan a 'head' of air to move, and used some 4" ducting bits from work, all parts sealed air tight with glazing tape
I then had to source a transformer capable of a 80w dc load and also dimmable (so i can regulate fan speed)
And i then plugged her in and tried it out! my god it moves some air! good job its dimmable and i can adjust the rpm later!
Now with something like this i like to go the extra mile and ive been dying to have an excuse to use some hardline tube for a build so i did! Props to Monsoon there hardline fittings are a work of art!
A tip to anyone using 16mm OD acrylic tube, 15mm copper plumbing pipe clips fit lovely! and used some off cuts as spacers!
Now when i ran up the fan for the first time i realised the top spacer bracket was too shallow and was choking the fan, so back to the drawing board on that one, out with the old and in with the new!
All painted and fitted!
I had a little carbon wrap left over from the last build so i thought this would look cool!
I then added these SEXY iso valves for draining down in the future!
As this section is going to be air tight i thought i best make a door!
And back from painting and fitted, the colour is called 'putty' which is middle class for cream! lol
Bit more hardline (the two pieces butted up will be replace buy one single length, justy need to find some longer than 600mm)
Oh also 3mm acrylic bonded into door appature
Then a bit of figuring out where things fit and what order i need to plumb the cooling
Worked the side panel to allow for the duct opening and the tubing pass through
same on the back
Then the job i love/hate the most! love the end result, but hate getting there! (too tight for laser cutting!)
And there we are, up to date-ish!
Hope you all enjoyed it so far!
FaNaTiiCz
