I thought today i would stick my computer in my old xbox case.
The case is quite bashed up so im going to buy a broke 360 on ebay and use that. I still need to sand it down where i have put holes in it, re-paint it and secure the front USB ports but apart from that im pleased with it.
My camera is not working at the moment but i should be able to get it working in the next few days so then i will upload lots of pics, i will keep this updated if you want but here is a quick pic took on my webcam.
The front power button works fine but its not the orginal one but one from my pc case which fits in well luckly and i have a reset switch at the back. I dont have the covers on at the moment that go on the top and bottom where the HDD normally goes as i didnt have any spares and they went when i sold my old 360. i am going to attempt to put a laptop dvd drive in and fit it into the 360 as there are cables that can convert them to pc sata and i will try and use the eject button that normally comes with the 360 if not its not a big issue.
The silver line accross the 360 is from a bad spray paint a did where i rushed it but i should sort that out soon.
tbh the cooling isnt that bad running browers msn etc as the cpu fan is really close to the hole in the side and if heat does get a problem i will just mount a fan on the outside where i put the girll.
What do you think?
~Danny
What do you think?
~Danny
I am going for a low profile gpu on a pci extender for this to
i have a xbox here as well i could try put it in there as well
