My problems never stop (BSOD help :()...
2 May 2004
Been getting some blue screens recently, Microsoft can't tell me what it is (error reporting thing) so I checked in my event logs and here's what it says:
Event Type: Error
Event Source: System Error
Event Category: (102)
Event ID: 1003
Date: 28/07/2006
Time: 02:41:48
User: N/A
Description:
Error code 100000d1, parameter1 00000002, parameter2 00000002, parameter3 00000000, parameter4 f7c30151.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 53 79 73 74 65 6d 20 45 System E
0008: 72 72 6f 72 20 20 45 72 rror Er
0010: 72 6f 72 20 63 6f 64 65 ror code
0018: 20 31 30 30 30 30 30 64 100000d
0020: 31 20 20 50 61 72 61 6d 1 Param
0028: 65 74 65 72 73 20 30 30 eters 00
0030: 30 30 30 30 30 32 2c 20 000002,
0038: 30 30 30 30 30 30 30 32 00000002
0040: 2c 20 30 30 30 30 30 30 , 000000
0048: 30 30 2c 20 66 37 63 33 00, f7c3
0050: 30 31 35 31 0151
The only thing that Microsoft tell me after I've sent them the error report is that it's something to do with a halted driver.
This is my only problem on this PC at the moment (apart from the external hard drive ftdisk which I think might be to do with overheating).
--Edit--
I really don't know if it's coincidence or not but it seems to be happening when running uTorrent... but then again I installed Azureus to see if it was uTorrent and the same thing happened. I really don't see how both could cause the same problem.
Thanks in advance :)
Craig.
Hi
I'm not sure what it could be straight off, but I'd try:
1) If the PC is overclocked, set it to stock
2) Check your system temperatures
3) Download Memtest (the DOS version) and run it for a few hours to see if they're any memory problems
4) What power supply are you using? Perhaps it isn't sufficient for your PC - check your voltage levels are all within +/-5%
Not overclocked
Temps are perfect
I will try memtest but this RAM has been tested in another PC and works perfectly
Also I'm using an Akasa Ultra Quiet 460W ATX 2.0 PSU. All voltages are looking good as well :)
Weirdly, the PC has only ever BSOD when running a torrent program, could it be something to do with a corrupt shell extension? Maybe a RegSeeker cleanup could do the trick as I really don't see anything else in torrent programs that could cause it.
Thanks for the help :)
Craig.
It did it again... torrent was running as well. It has never ever BSOD without a torrent program running.
This time I got a little more information:
DRIVER_IRQL_NOT_LESS_OR_EQUAL
Then at the bottom it said:
NET8511.sys address F7AC8151 base at F7AC7000, datestamp 3a35a42f
--Edit--
Right, I just decided to re-install my USB ethernet adapter driver (onboard LAN seems to be broken, I'm going to try get it working again). I noticed during the reinstall of the drivers that it was installing NET8511.SYS so either the driver was corrupt or the hardware is broken.
Anyway, I'm going to try get onboard working again now, wish me luck :p
-- Edit 2 --
Just reinstalled the drivers (newest ones from ASUS site) for the onboard LAN & plugged it in. All it's doing is saying that it's unplugged.
Any ideas how I can fix it please? It looks fine in the device manager (in it's right place and doesn't have any warning signs by it or anything)
-- Edit 3 --
Right, just checked the event viewer and found this:
Event Type: Error
Event Source: HTTP
Event Category: None
Event ID: 15005
Date: 31/07/2006
Time: 03:09:06
User: N/A
Computer: SCAR
Description:
Unable to bind to the underlying transport for [::]:2869. The IP Listen-Only list may contain a reference to an interface which may not exist on this machine. The data field contains the error number.
Data:
0000: 00 00 04 00 02 00 52 00 ......R.
0008: 00 00 00 00 9d 3a 00 c0 ....:.À
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
0028: 0e 00 00 c0 ...À
I'm hoping it's just a software error that's making my onboard LAN not work, I really would like to get it working again >.<
Another edit:
I just set a custom IP in the TCP/IP options, then disabled and re-enabled it. It connected for a few seconds but then went back to network cable unplugged :(
Also, just found this in the event viewer as a warning:
Event Type: Warning
Event Source: Server
Event ID: 2504
Date: 31/07/2006
Time: 03:16:49
User: N/A
Computer: SCAR
Description:
The server could not bind to the transport \Device\NetBT_Tcpip_{03164EFB-BA9C-4AAD-B6E0-C7E2C8A0A8F2}.
Data:
0000: aa 05 00 00 ª...
Thanks,
Craig.
just did a search...
YMPTOMS
loadTOCNode(1, 'symptoms'); When you experience a deadlock in ASP.NET, the following event may be logged in the Application event log: Event Type: Error
Event Source: ASP.NET 1.0.3705.0
Event ID: 1003
Date: 4/24/2002
Time: 6:18:23 PM
User: N/A
Computer: ComputerName
Description:
aspnet_wp.exe (PID: xxx) was recycled because it was suspected to be in a deadlocked state. It did not send any responses for pending requests in the last 180 seconds.
http://support.microsoft.com/?id=325947#top
RESOLUTION
loadTOCNode(1, 'resolution');A supported fix is now available from Microsoft, but it is only intended to correct the problem that is described in this article. Apply it only to computers that are experiencing this specific problem. This fix may receive additional testing. Therefore, if you are not severely affected by this problem, Microsoft recommends that you wait for the next .NET Framework service pack that contains this fix.
To resolve this problem immediately, contact Microsoft Product Support Services to obtain the fix. For a complete list of Microsoft Product Support Services phone numbers and information about support costs, visit the following Microsoft Web
NOTE: In special cases, charges that are ordinarily incurred for support calls may be canceled if a Microsoft Support Professional determines that a specific update will resolve your problem. The typical support costs will apply to additional support questions and issues that do not qualify for the specific update in question.
NOTE: This hotfix does not resolve deadlocks; this hotfix only provides instrumentation to troubleshoot and to diagnose deadlocks. For more information about how to use this hotfix to troubleshoot and to diagnose deadlocks, see the "More Information" section of this article. The English version of this fix has the file attributes (or later) that are listed in the following table. The dates and times for these files are listed in coordinated universal time (UTC). When you view the file information, it is converted to local time. To find the difference between UTC and local time, use the Time Zone tab in the Date and Time tool in Control Panel. Date Time Version Size File Name
09-Jul-2002 06:46 1.0.3705.294 192,512 Aspnet_isapi.dll
09-Jul-2002 06:46 1.0.3705.294 24,576 Aspnet_regiis.exe
09-Jul-2002 06:46 1.0.3705.294 28,672 Aspnet_wp.exe
09-Jul-2002 19:00 1.0.3705.294 1,187,840 System.web.dll
09-Jul-2002 06:39 19,332 Aspnet_perf.ini
21-Mar-2002 04:31 8,709 Smartnav.js
21-Mar-2002 04:31 7,003 Smartnavie5.js
Back to the top
STATUS
loadTOCNode(1, 'status');Microsoft has confirmed that this is a problem in the Microsoft products that are listed at the beginning of this article. http://support.microsoft.com/?id=325947#top
MORE INFORMATION
loadTOCNode(1, 'moreinformation'); After you install this hotfix, the native debugger can break in on the process when a deadlock occurs. This hotfix adds instrumentation to call the DebugBreak function when a deadlock occurs in the ASP.NET worker process (Aspnet_wp.exe). The following registry key instructs ASP.NET what to do when a deadlock occurs: •DebugOnDeadlock = 0 (no break)•DebugOnDeadlock = 1 (Break into Aspnet_wp.exe only)•DebugOnDeadlock = 2 (Break into Aspnet_wp.exe and Inetinfo.exe) The ASP.NET deadlock detection is automatically disabled when a native debugger is attached to the ASP.NET worker process (Aspnet_wp.exe). However, it is helpful to obtain a dump file before the process recycles. To have a debugger attached and to still have deadlock detection enabled, you must set the following registry key to the appropriate value: •UnderDebugger = 0 (Debugger can be attached, and process can be recycled)•UnderDebugger = 1 (Debugger can be attached and stops process from recycling)NOTE: When you finish debugging, Microsoft recommends that you delete these registry entries.
Generate Dump Files for Diagnosis
loadTOCNode(2, 'moreinformation'); To troubleshoot and to diagnose a deadlock, you must generate a dump file of the Aspnet_wp.exe process, the Inetinfo.exe process, or both processes immediately before the Aspnet_wp.exe process is recycled. With the instrumentation that is added to ASP.NET, you can determine when this occurs. After dump files are generated, you can analyze these dump files to determine the cause of the deadlock.
To generate dump files, follow these steps: 1.Install this hotfix, or make sure that you have a later version on the computer that experiences the deadlock behavior.2.If the native debuggers are not already installed on the computer, install the debugging tools. To download the debugging tools, visit the following Microsoft Web site:
3.Follow the steps in the "Modify the Registry" section to add a new DWORD registry entry that is named UnderDebugger under the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ASP.NET registry subkey, and then set the value of UnderDebugger to 0.4.Follow the steps in the "Modify the Registry" section to add a new DWORD registry entry that is named DebugOnDeadlock under the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\ASP.NET registry subkey, and then set the value of DebugOnDeadlock to 0.5.In the directory in which the native debuggers were installed (the default location is C:\Program Files\Debugging Tools For Windows), locate the ADPlus.vbs file.
Depending on the version of ADPlus that you have, you may have to put this constant in the ADPlus.vbs file. At a command prompt, locate the directory where you installed the debuggers. Run the following command at the command prompt:ADPlus.vbs -HELP
If the -CTCFG switch does not exist, add the following constant:Const Full_Dump_on_CONTRL_C = TRUE If the -CTCFG switch does exist, use that switch at the command prompt.6.At a command prompt, change directories to the debugging tools directory, and then run one of the following commands:
NOTE: Make sure that you change the path to the path that you want the files to be created in. •To attach to the ASP.NET worker process (Aspnet_wp.exe) only, run the following command:adplus.vbs -crash -pn aspnet_wp.exe -o c:\Path_to_Put_Files_in
•To attach to the Inetinfo.exe and the Aspnet_wp.exe processes, run the following command:adplus.vbs -crash -pn inetinfo.exe -pn aspnet_wp.exe -o c:\Path_to_Put_Files_in
NOTE: Make sure that the Aspnet_wp.exe process is started before you run either of these commands.
NOTE: If you are running ADPlus.vbs through Terminal Server, click the article number below to view the article in the Microsoft Knowledge Base: 323478 (http://support.microsoft.com/kb/323478/EN-US/) PRB: You Cannot Debug Through a Terminal Server Session
7.Set the DebugOnDeadlock registry entry to one of the following values: •DebugOnDeadlock = 1 (Break into Aspnet_wp.exe only)•DebugOnDeadlock = 2 (Break into Aspnet_wp.exe and Inetinfo.exe)
8.When a deadlock occurs, notice that dump files are created automatically, and that the processes that were attached are restarted.9.After the deadlock occurs, delete the UnderDebugger and the DebugOnDeadlock registry entries. If you do not delete these registry entries, you may receive an error message the next time that a deadlock occurs.Back to the top
Modify the Registry
loadTOCNode(2, 'moreinformation');WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
To add the UnderDebugger DWORD value, follow these steps: 1.Start Registry Editor.2.Locate and then click the ASP.NET value under the following subkey in the registry:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft
3.On the Edit menu, click DWORD, type UnderDebugger, and then click OK.4.Double-click UnderDebugger, and then change the data value to 0 or 1.5.Quit Registry Editor. To add the DebugOnDeadlock DWORD value, follow these steps: 1.Start Registry Editor.2.Locate and then click the ASP.NET value under the following subkey in the registry:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft
3.On the Edit menu, click DWORD, type DebugOnDeadlock, and then click OK.4.Double-click DebugOnDeadlock, and then change the data value to 0, 1, or 2.5.Quit Registry Editor.Back to the top
APPLIES TO
•Microsoft .NET Framework 1.1 Service Pack 1
It sounds like something is preventing your network driver from initialising correctly. The first culprits for this is crappy personal firewall software. So uninstall any of that. Secondly uninstall any anti-virus software or other security software.
Now try reinstalling the NIC driver.
If you like, upload some of the minidumps from c:\windows\minidump and I'll take a look in a debugger.
Well it hasn't BSODd since I reinstalled NET8511.sys (ethernet USB adapter drivers).
If it does it again I'll do what's been suggested :)
Thanks,
Craig.
