Ian, that looks like a single instance of prime your running there with large FFT's, is that right?
If it is you need to be running prime 95 v25.5 to stress all 4 cores at once using small FFT's, then you will see some higher load temps, just to give you an idea my 3.5Ghz Q6600 under a single instance of prime will hit around 44C, but with all 4 cores stressed using prime v25.5 it will hit 59C.
If your already doing that though then just ignore me
