Hows it going guys
Just about finished my first CPU loop with not too many problems along the way.
After a good bit of running I've noticed foam accumulating in the top of the res.
the system has been leak tested for over 10 hours with no leaks. I've tried turning the pump to a low speed to avoid turbulence and also ran the system for a few hours with the top plug removed from the res, but to no avail.
i spoke to a fella a couple of weeks ago who advised me to run a full 50ml bottle of anti-corrosion fluid through my loop which is about 1 litre in capacity. i got to about 20ml and stopped because of clouding. is this level of anti-corr fluid to much and possibly the cause of the foaming?
any help or advice would be most appreciated.
here's a couple of pics to show you what im working with.
