Not a new build but after being built for a while and now been to a couple of lans it needed abit of tidying up. I also got rid of my rear UV/LED fans for the standard Silverstone items and took most things to bits for a decent air dusting!
Looking to go Core i7 early next year if all goes to plan, but for the time being the spec is:
Motherboard: Asus Maximus Extreme
OS: Windows XP Pro SP3
PSU: 800w Tagan TG-800-U33 2ForceII
CPU: Intel Core 2 Duo E8600 E0 3.3Ghz @ 4.5Ghz
Memory: 2046MB OCZ Platinum DDR3 PC3-14400
Hard Drive 1: Seagate 500Gb 7200RPM 32MB Cache
Hard Drive 2: Seagate 500Gb 7200RPM 32MB Cache
Hard Drive 3: Seagate 320Gb 7200RPM 16MB Cache
Video Card: 512MB MSI 8800 GTS OC @ 855/2025/1100
Sound Card: Sound Blaster Audigy 2 ZS
Case: Silverstone TJ07B-W
Rad: ThermoChill PA120.3
CPU Block: D-TEK FuZion + Nozzle Pack
GPU Block: EK-FC88GT 8800GT/GTS G92
Pump: Swiftech MCP655-B
Tubing: Masterkleer 7/16" ID 5/8" OD PVC
Res: XSPC 5 1/4 Bay Reservoir
3DMark06: 17765
Nothing amazing compared to some of the mods and spec of some of the machines on here, but never the less:
Dan
3DMark06: 17765
Dan
