My turn for an upgrade
The 3gig Palit is £429, the Gainward though is the 1 priced at £499.
The Palit would be cheaper than the Lightning, but the Lightning will probably overclock better, urgh what a chore.
If budget isn't an issue then the 6990 seems awesome.
Or for a sensible budget go for 6950's, flash to 6970 and crossfire for insane performance for a great price!
tbh there's not a lot that a 580 at stock speeds can't munch for breakfast...no real need to OC the gpu
To be honest at that res i wouldn;t recommend crossfire or SLI. The gameplay will be less smooth and temps will be higher for very little gain in performance over a single card.
A 580 should tear through everything you need at that res. You can then OC later down the line when you need to.
If you want AMD, then a 6950 rev1 unlocked to 6970 is probably best bang for buck. The extra VRAM will help later down the line as well.
