Matt7613 said:I'll post some pictures up of it all later on, however I have to say I think it looks rather good!
InvaderGIR said:Colour deffinatly!
It does look messy though, and that rad isn't going to be of much use with that pipe trailing![]()
bringerofdecay said:for his CPU block by the looks of it![]()
well, its creating more of a loop, and the barbs restrict water flow, but i wouldn't worry, it wont be by a huge difference, and i dont see how the T-line will make the res useless, as the res comes before it in the loopMatt7613 said:Only problem with having it next to the PCI slots is that I'll have to remove my 120mm fan.
Could you explain to me aswell how it is restricting the loop as I am a noob and need to learn![]()
Thanks,
Matt.
Matt7613 said:Thanks a lot!
How much would a valve set me back?
Here's the colour pictures which were requested!
Thanks,
Matt.
DaveMac said:The t-line replaces the res as the filling / bleed point, thus the res is redundant.
Matt7613 said:Ill have a play later and sort it all out. Then ill see what you say?
