- 20 Apr 2014
- Herts/uk
Needs more work but getting it done bit by bit
what you're talking about is called reverse ATX. look it up a few people have made the modification. it's hard but not impossible.
and good job so far!
Ah cheers, im suprised theres not more need for them really
I guess it all comes down to taste really. I like a more "clasic" orientation but I do appreciate the work put into a nice reverse ATX, especially with nice watercooled graphics cards.
It's actually better for temps as well because it allows the GPU heat to escape easier rather than heating the CPU up.
Nice build what temps are u getting on your cpu and 780s?
nice one there! and you can do a screenshot during your runs by pressing F12
Its interesting to see the temps of those hybrid cooled graphics cards over a full waterblock. I have 2 780's in my build but i have the XSPC block on both and the difference in temps is dramatic. That could be down to you only having the 1 rad to cool CPU + Motherboard + 2 780's! Do you plan on adding more rads to the build?
You think my temps are high?
