MyBook Keeps Reconnecting
17 Oct 2002
Ashburton Grove
I'm using Vista x64 Ultimate and my, now a couple of years old, MyBook keeps disconnecting, then reconnecting itself, often opening the Autoplay options afterwards.
I have recently reformatted to NTFS to try and cure this problem, to no avail.
It's only used for storage, so there shouldn't be any driver problems.
Is it on it's way out, or is there a solution?
Cheers,
Kev
