MYSQL Help comparing 2 tables
18 Oct 2002
Need help comparing titles from 2 databases, looking for a match on the model number in the title, lots of different models
eg closest match
500D 500-D (i.e. 500)
S930 S 930 (i.e. 930)
This query works only if the title is the exact same
Code:
Select
cameras.title,
cameras.sku,
cameras.price
where
cameras.title like concat('%',cameras_digital.title,'%');
Is there a way to match parts of the title?
Thanks in advance
Regards
Dave
I'd use regexes.
step one - remove all punctuation etc to leave just letters and numbers.
compare each with each other
extract a substring of e.g. 3 or more numbers from 1 and compare with the other
as above but for text.
Doe that help?
I'd use regexes.
Doe that help?
Hi
I looked at the REGEXP function, but could work out how to write the query, not used it before.
Code:
Select
cameras.title,
cameras.sku,
cameras.price
from
cameras,
cameras_digital
where
cameras.title REGEXP('%',cameras_digital.title,'%');
returns no matches
I had a look at the examples
http://www.tutorialspoint.com/mysql/mysql-regexps.htm
Are you able to give an example?
regards
Dave
i haven't done it directly in SQL before, I'd use php or something but a regex might be something like this:
s/[^a-zA-Z0-9]+//g (find everything not alphanumeric one or more times and replace with 'nothing')
s/([0-9],{3,})/%1
*something* like that. I'd need to go and look it up to be sure and depending where and you are implementing the regex the syntax may be different....
s/([0-9],{3,})/%1
OK have removed all punctuation etc but this query doesn't return any values
Code:
Select
cameras.title,
cameras.sku,
cameras.price
from
cameras,
cameras_digital
where
