mySQL.. help please :)
12 Mar 2009
I need to view all records which are in the range : (today + one month)
dateline_from is my date time (UNIX format).
I know how to convert UNIX to normal date time its FROM_UNIXTIME(date,format).
How would i do this... Using MySql ??
a bit of statment which might help
SELECT * FROM `event` WHERE FROM_UNIXTIME( `dateline_from` , format)
If you're using 31 days as a month, just do everything from now() to now() + (86400 x 31)
Does
Code:
SELECT * FROM `event` WHERE FROM_UNIXTIME( `dateline_from` , format)  between CURDATE() and DATE_ADD(CURDATE(), INTERVAL 1 MONTH);
Work?
You could replace CURDATE() with FROM_UNIXTIME( `dateline_from` , format)
