mysql help
1 Mar 2006
trying to get a irc roomlist on my webpage
using below script from net
Code:
<?php
      *    server configuration
    define ('IRC_SERVER', 'irc.xxx.net);
    define ('IRC_PORT', 6667);
    define ('IRC_REFRESH', 1);        // minutes
      *    DB Tables
    define ('T_CONFIG', 'irc_config');
    define ('T_CHANNEL', 'irc_channel');
      *    connect to database
    mysql_connect ("xxxxxxxx", "xxxxxx", "xxxx");
    mysql_select_db ("irc");
      *    uncomment to create tables on first run
//    create_tables ();
      *    get channels and output
    $arr_channels        =    db_get_channels ();
    foreach ($arr_channels as $arr_channel)
        echo join ("<br>n", $arr_channel);
        echo "-----------------<br>n";
      *    db_get_channels
      *    - return list of all channels either by asking database or IRC Server
    function db_get_channels ()
          *    get last update timestamp
        $raw            =    mysql_query ("SELECT UNIX_TIMESTAMP(lastupdate) FROM ".T_CONFIG);
        list ($ts_lastupdate)    =    mysql_fetch_row ($raw);
        mysql_free_result ($raw);
          *    too old?
        if ($ts_lastupdate < (time() - (60*IRC_REFRESH)))
              *    block parallel processing by updating lastupdate to current time
            mysql_query ("REPLACE INTO ".T_CONFIG." (lastupdate) VALUES (NOW())");
              *    get channels
            if (($arr_channels = irc_get_channels ()) == false)
                  *    failed, return with db-source
                return db_get_channels ();
              *    clear existing list
            mysql_query ("TRUNCATE ".T_CHANNEL);
              *    insert channels into database
            reset ($arr_channels);
            $arr_insert[]        =    array ();
            foreach ($arr_channels as $str_channel => $arr_data)
                $arr_insert[]        =    "('".mysql_escape_string($str_channel)."', ".intval($arr_data[0]).", '".mysql_escape_string ($arr_data[1])."')";
                if (sizeof ($arr_insert) > 25)
                     mysql_query ("INSERT INTO ".T_CHANNEL." (channel, users, topic) VALUES ".join(',', $arr_insert));
                    unset ($arr_insert);
                $arr_return[]        =    array ($str_channel, $arr_data[0], $arr_data[1]);
            unset ($arr_channels);
              *    some entries left?
            if (sizeof ($arr_insert))
          *    get input from DB
        else
            $raw        =    mysql_query ("SELECT channel, users, topic FROM ".T_CHANNEL);
            while ($arr_return[] = mysql_fetch_assoc ($raw))
            { /* hi there :) */ }
          *    return arary of channels
          *        [0]    =    #channel
          *        [1]    =    users
          *        [2]    =    topic
        return $arr_return;
    /**    <- end of db_get_channels () */
      *    irc_get_channels
      *    - connects to IRC Server and returns a multidimensional array of all channels
    function irc_get_channels ()
          *    open socket to server
        $hwnd_irc        =    fsockopen (IRC_SERVER, IRC_PORT);
          *    connection failed?
        if (!$hwnd_irc)
            return false;
          *    use random nick & identification
        $str_nick        =    chr(rand(65,90)).time().rand(1,10000);
        fputs ($hwnd_irc, "USER ".$str_nick." ".IRC_SERVER." ".IRC_SERVER." :Channelreaderrn");
        fputs ($hwnd_irc, "NICK ".$str_nick."rn");
          *    get data until we're finally connected & verified
        $arr_channels        =    array ();
        while (!feof($hwnd_irc))
            $str_line    =    fgets ($hwnd_irc, 1024);
              *    response to PING requests
            if (substr($str_line,0,5) == 'PING ')
                fputs ($hwnd_irc, "PONG ".trim(array_pop(explode(':', $str_line)))."rn");
              *    switch between response ID's
            $arr_line    =    explode(' ', $str_line);
            switch ($arr_line[1])
                  *    "End of Motd" (376)
                case 376:
                      *    send LIST request
                    fputs ($hwnd_irc, "LISTrn");
                    break;
                  *    channel list
                case 322:
                      *    0 = sender
                      *    1 = ID
                      *    2 = target
                      *    3 = channels name
                      *    4 = users in channel
                    $arr_channels[$arr_line[3]]    =    array ();
                    $arr_channels[$arr_line[3]][0]    =    $arr_line[4];
                    $arr_channels[$arr_line[3]][1]    =    trim (substr ($str_line, strpos($str_line, ':', 5)));
                    break;
                  *    End of List
                case 323:
                    fputs ($hwnd_irc, "QUITrn");
                    break 2;
        fclose ($hwnd_irc);
          *    got no list?
        if (!sizeof ($arr_channels))
            return false;
          *    return hash of all channels
          *        [#channel]
          *    with an array of users & topic
          *        [0]        =    users
          *        [1]        =    topic
        return $arr_channels;
    /**    <- end of irc_get_channels () */
      *    create_tables
      *    - create table structure
    function create_tables ()
        $arr_query[]        =    "DROP TABLE IF EXISTS `irc_channel`";
        $arr_query[]        =    "CREATE TABLE `irc_channel` (
                  `channel` varchar(32) NOT NULL default '',
                  `users` smallint(5) unsigned NOT NULL default '0',
                  `topic` varchar(255) NOT NULL default '',
                  PRIMARY KEY  (`channel`)
                ) TYPE=MyISAM";
        $arr_query[]        =    "DROP TABLE IF EXISTS `irc_config`";
        $arr_query[]        =    "CREATE TABLE `irc_config` (
                  `lastupdate` datetime NOT NULL default '0000-00-00 00:00:00'
                ) TYPE=MyISAM";
        foreach ($arr_query as $str_query)
            mysql_query ($str_query);
    /**    <- end of create_tables () */
i cant get it too connect..think its because of the mysql_connect ("localhost", "login", "password");
part
all database user and passes are correct and stuff
get the below response.
Code:
Warning: mysql_connect() [function.mysql-connect]: Unknown MySQL server host 'denbyuk@locahost' (1) in /home2/denbyuk/public_html/channels.php on line 18
Warning: mysql_select_db() [function.mysql-select-db]: Access denied for user 'denbyuk'@'localhost' (using password: NO) in /home2/denbyuk/public_html/channels.php on line 19
Warning: mysql_select_db() [function.mysql-select-db]: A link to the server could not be established in /home2/denbyuk/public_html/channels.php on line 19
Warning: mysql_query() [function.mysql-query]: Access denied for user 'denbyuk'@'localhost' (using password: NO) in /home2/denbyuk/public_html/channels.php on line 46
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in /home2/denbyuk/public_html/channels.php on line 46
Warning: mysql_fetch_row(): supplied argument is not a valid MySQL result resource in /home2/denbyuk/public_html/channels.php on line 47
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home2/denbyuk/public_html/channels.php on line 48
Warning: mysql_query() [function.mysql-query]: Access denied for user 'denbyuk'@'localhost' (using password: NO) in /home2/denbyuk/public_html/channels.php on line 58
Warning: mysql_query() [function.mysql-query]: A link to the server could not be established in /home2/denbyuk/public_html/channels.php on line 58
so on..
please HELP! lol
Errrrrrrrrrrr you might want to read the error properly, it might help (you never know).
Either change to just 'localhost' or give your user the necessary privileges.
