MySQL Parameters and Flash CS3
6 Dec 2007
Hey all, not been in here in a while, but I was wondering if you could help.
In something like VB.NET with SQLServer you can add paramters to a query by doing something like Parameters.AddWithValue, but I need to do something similar using Flash CS3, Actionscript 2.0 and MySQL.
Basically, I would like to get a value from a combo box, and pass that value to a SELECT query using that value.
Can anyone help a very confused person?
TIA :)
You cant really communicate directly with MySQL from within Flash without some 3rd Party Apps. Best way to do it is to pass the flash content to a php script which then does the integration with MySQL, and then the php script can return results to flash. This is how I run my flash bulletin board at http://forums.swfbb.com The flash content is passed to MySQL via PHP and then back again to display results/data.
If you need any help with it dont hesitate to ask :)
