Mysterious PC damage
17 Feb 2010
London
Which of the following is likely to cause the damage:
1) a live ethernet cable with a heavy duty staple through it
2) soldering a vga cooler fan cable which the PC is powered on and running
The damage to the motherboard is a no longer functioning onboard ethernet port and 6 onboard multi-coloured sound jack ports.
I don't know why you'd do either. But the second is probably the one that killed it.
That said, having a faulty ethernet port means the first is a bit odd...
kd
well the staple was accidental, whilst the cable was being routed a day or two before
the soldering was obviously a mistake, but i didnt think heat alone would short something out
The heat from the soldering iron isnt the concern IMO.
The earthing/shorting of a live circuit through the iron seems a bit more plausible.
Motherboard components are very sensitive to voltage change, as we all know.
Juice is trying to go from A to B.
You chuck a soldering iron tip in the middle of that and the juice is getting channelled through the iron to -V (or its equivalent)
B is expecting some juice to do what ever it needs it for and cant.
I'm sure someone else will be along soon to either back me up or shoot me down in flames. :D
ok, so i maybe i got lucky too
just a bit random how the onboard sound and ethernet ports were killed. maybe could have been a lot worse damage, cpu, ram, gpu etc...
Why on earth would you be soldering onto a live system?? :confused:
That's just asking for trouble.
lol. Sorry for your loss... I would go with soldering iron... but...
When you say 'live' ethernet cable.. do you mean the type that also carry power?
Also... are you sure these incidents are connected, and it's not coincidence (i.e. a software issue?)
