- 20 Jan 2011
- Bristol
Hello
My PC is currently just below the recommended specs with the following hardware:
B450 Motherboard
Ryzen 1600x CPU
AMD RX 6600 GPU
32 GB RAM
The current issue I have is while riding, MyWoosh occasionally freezes (few seconds), although most of the time I get a steady 30 fps
The display settings are set to auto and I'm running 1080p to my TV.
I am aware of the specs listed at:
https://www.mywhoosh.com/docs/what-devices-are-compatible-with-mywhoosh/
Anyone else use MyWhoosh? I’m wondering if the issue is maybe the 1600x single thread performance?
I believe it uses the Unreal engine if that helps?
Thanks
B450 Motherboard
Ryzen 1600x CPU
AMD RX 6600 GPU
32 GB RAM
Thanks
