I am looking for some NAS storage - 160-250 gb
The main use of this will be to store multimedia that will be accessed by my xbox + xbox media centre.
Because of this, it must be accessed by standard tcp/ip rather than some of the proprietary protocols, used for example in the netgear sc101, which require software to be installed on the clients so that the drive appears as a local drive.
I would also like to connect the drive to a local computer by firewire or usb2 so that I can fill it up quickly rather than over a 100mbit network.
OR,are there any gigabit lan drives and it so, if I connected one to my switch (100/10) and directly (via crossover cable) to one of my gigabit lan ports on my motherboard, would it transfer prefereably over the direct gigabit link.
cheers for any help
cheers for any help
