n00b help please!!
6 Jul 2010
Taunton, Somerset
gonna be building one for my brother with an athlon x4 630. if I dont increase the voltage but oc, will the chip stay the same temp. as it would without overclocking? also how essential is an aftermarket cooler for this athlon? thanks guys
I wouldn't start messing with voltages until you've seen how much extra you can get at stock. Play with the clock speed and/or multiplier until you have something stable then leave it like that for a while, keeping an eye on temperatures. If everything is good after a week or two of normal use, increase the voltage slightly and repeat. The key to getting good at OC is to take things slowly, always monitor temperatures, and always increase settings by small steps, testing for stability each time.
