There is no reason why you cant do this, clearly doign houses you have a reasonably logical mind and can use your hands.
Get the halfords set, the £199 set is good value (especially when on offer) and it comes with lifetime guarentee, its easy to add to using their bargain bin which is where you find odd, but useful things like 15 or 18mm sockets (used on audi's and others).
Grab a breaker bar for extra leverage, a torque wrench, jack and stands and you're set, there is very little else you will need although when you start there will be lots you want. Between halfords and machine mart you can get everything you like and whilst the latter gets slagged off in here i like them, the kit is good and its cheap, i abuse mine building and destroying landrovers and things so it doesnt have an easy life but it never gives me grief.
If you get into air tools then consider axminster tools, superb quality and cheap too.
The jobs you listed, brakes, radiator etc can all be done with common sense, courage and a haynes manual, the head gasket is a fair bit more complex but certainly not unachievable.
