Hi all, wall of text incoming, tl:dr at the bottom.
I consider that I have an above average knowledge of computers however this knowledge is limited to building, fault finding etc on desktop PC’s. When it comes to things outside of this, especially networks I hold my hand up to being an utter noob so I have some questions.
My current set up is using virgin media superhub which acts as the router also and then cat5 cables run throughout the house. Which leads to a couple of questions:
1.Does anyone use a Virgin superhub with NAS or is it advisable to get a stand alone router? I have tried to find info on this but all my weak Google skills seem to find is routers which allow usb hdds to be attached and used as NAS which isn’t what I want.
2. Either way, what is the best way to test transfer speed over a network? I am aware I could simply share a file on one PC and copy it to another timing it then file size / time gives transfer speed but I don’t know whether this is actually the best way to calculate it. From my limited knowledge though being cat5 cable throughout then transfer speeds should be pretty reasonable though.
Now for the actual NAS box,
My current htpc is running 2 x 2Tb drives, roughly about 3.5Tb full, it needs a good sort out but I doubt it will reduce in size too much. I was looking at getting a 4 bay NAS, but if I fill it with 2Tb drives if I consider using any RAID set up then the NAS would be almost full just by what is on my htpc now. So I am considering running the NAS with just the drives in, it doesn’t give me any security on drive failure but I don’t really need that as the important docs are already backed up and I could just rip blurays again if need be (bit of a PITA but would rather have the extra storage).
So another question, from reading around it would seem that data transfer rates from a NAS are lower than the rate achievable if the hdd was local. Obviously a local hdd can transfer data quick enough to watch HD content / Blu ray rips but is this possible streaming from NAS? Or is RAID my only option for this?
I was looking at getting an off the shelf 4 bay NAS box, either QNAP Turbo NAS TS-412 or Synology Diskstation DS413J. They seem like decent enough enclosures and searching this forum get good reviews but for that sort of price I could get an HP N45L Micro-server (running MS Home Server or FreeNAS). Using the HP server seems a more complicated option to set up but ultimately gives more options once up and running so really leaning towards that unless someone can suggest why it isn’t a valid option?
Thanks for any advice, Greboth.
TL;DR
Questions
1. Virgin Superhub modem router combo ok for NAS?
2. Best way to test transfer of a home network?
3. Leading from question 2, without running a RAID array can NAS transfer enough data for streaming HD content.
4. Which to buy - QNAP Turbo NAS TS-412 or Synology Diskstation DS413J or HP proliant microserver N54L ?
TL;DR
Questions
I opened the manual but at 160 (180?) pages I didn't read it. I assumed that something like that would be listed as a 'feature' by OCUK/competitors/QNAP website but apparently not.
