NAS Box
18 Oct 2002
Leicestershire
Morning,
Looking for a NAS box, 2 bay, needs to have the following.
Timemachine ability that works with Mavericks.
BitTorrent client.
Share by user/rights etc
Trying to decide between a cheap 0 drive box and then add drives (1 to start with and the empty for expandability if needed later) or get something that comes with drives, the Buffalo Linkstation Duo ticks a lot of boxes, its 2x2Tb drives but tbh 4Tb will probably do.
Would be a bonus if theres the ability to do DNLA or HDMI into a TV from the box itself so it can be a media player although thats not a requirement..
I've got a DS212J from Synology, absolutely great!! So many features and such great price, it just 'works' haha
Just make sure if you do get a Synlogy you get a current model.
DS212:
DS = Disk Station
2 = 2 drive bays
12 = 2012 (year of manufacture)
Hence why i would recommend the new DS214 series.
DS = Disk Station
2 = 2 drive bays
14 = 2014 (year of manufacture)
Nothing, the asustors are fantastic. Not as many mobile apps as Synology but they perform great. The built in htpc element also works well
I've reviewed both the 6 and 3 series and have a 204te on the way to review. They are tremendous value which I think is a deliberate disruption by Asus to get a foot in
Would love to see your 204te review when it happens, I was going to buy a synology 212j last year due to your reviews but circumstances changed and I wasn't in the market for one anymore. Now I'm back on looking for a nas which would be media centre based.
sorry for the thread hijack op, was just curious on WD's opinions.
In that case I would definitely go for an Asustor. The 2 series TE or a 3 series would be fantastic. Mobile apps are slowly catching up with the likes of Synology.
That asustor unit looks pretty good...
If you are interested in any of my reviews I normally post up here but you can also find them HERE
I've also recently started expanding with Bitfenix and a few other nas vendors.
Yeah £200 inc drives, I was originally looking at an empty unit, putting one 3/4tb drive in it and using that, leaving a spare bay for future use..
If you have any suggestions around that, that could work still if you know of a bare unit that'll tick the same boxes as the two units above..
I've never really used D-Link for this sort of thing tbh
Last Buffalo kit I used was poor network performance on the old Terastations
how come the asustors which have hdmi out (for media streaming) more ram and a better CPU and are cheaper dont get a look in? the TE even has infrared for a remote and the software seems a doddle and benefits from 3rd party apps as well
http://www.tweaktown.com/reviews/58...bay-consumer-nas-appliance-review/index2.html
What am I missing?
I have this asustor Great nas. Didn't buy the remote as an app is available for apple / android, so I use that.
Hdmi works great to.
I had a DNS-320 (not the L version you've chosen mind you) and it's in a box in the cupboard because it's good for **** all except storing stuff. It could just about handle streaming music to my digital controller. So it was absolutely useless for streaming movies. Not sure how the L version compares though. The OS on the Dlink is crap as well. Synology's DSM is just all round better in every way.
Lol so that's a possible mark against the DNS then, will check the spec on the L compared to the unit you had..
If you want a NAS which actually does stuff, spend some extra £ and get a quality unit.
D-Link, buffalo etc are all trash. HDDs with features that don't work basically.
