One of my WD drives in my 'server' has chucked a bad block, so going to pull it and put something else in there..
However, given WD's SMR/CMR Red issue from a few years ago I'm going to steer clear of WD drives, so thinking Seagate IronWolf or Toshiba NAS drives.
Needs to be SATA, something that's not old and likely to go EOL in the next 18 months or so as I'll slowly swap out my other drives to the same make/model.
5400rpm class drives will do as its mainly just used for file storage, all of my VM's are on an NVMe drive, they will be sat in a Node 304 case and there's 4 of them all sat in the drive bays, they have a pair of fans drawing air over them so don't get overly hot, drives usually report mid to low 30's.
Anyone got any suggestions or recommendations?
