NAS Network speed explained?
1 Jan 2019
Hello,
If a NAS with 6 gigabit/s HDD's and two Gigabit Ethernet ports connected with Cat6 to a Gigabit switch why does a disc speed checker only show 100 mb/s
With link aggregation you would see 200 mb/s
Why so low?
Thanks
That's not how link aggregation works unfortunately. All it means is if one link is at 100% the other link if free to be used still, it doesn't combine them for double the throughput on a single transfer.
So basically you can have 2x 110mb/s transfers, but not 1x 220mb/s transfer.
Fair enough. Thanks for that. I'm still wondering why even at 220mb/s its so low? when everything in the network is gigabit?
Gigabits, not gigabytes. So divide it roughly by 8 to get rough max throughput In megabytes per second
So theoretical gigabit speed is roughly 120Megabytes max. If your actually getting 100MB/s that's pretty good considering.
Secondly, just cause the HDDs are connected to 6 gigabit sata connector, the drives themselves don't work at that speed. Most hard drives are in the region of 100MB/s too.
Your setup seems to be working as far as it can.
