NAS / VHDx question (defrag)
11 Jun 2003
The Shadows (london)
Is it a good idea to have a virtual drive stored on a NAS drive, mount that drive to a server and then use that instead of mapping a drive? also is defragging the vhd ok to do over the network?
Sounds like a rather convoluted, what kind of file system are you using?
I personally use ZFS in RAIDZ configuration. No expert but am fairly certain you don't need to defrag it.
Using NTFS. i've noticed I'm losing a lot of space (space on disk due to lots of small files) so was thinking the VHD would solve that issue as it would fill up all the available clusters to full?
