Navfree GPS users, it there a routing option that is a compromise 'fastest' and 'shortest' route?
4 Jan 2004
¯\_(ツ)_/¯
As title really, I've found shortest has been known to take me down dirt tracks, and fastest tend to only stick to A roads which isn't ideal.
I haven't had much of a chance to experiment with the other options such as 'economy' but I was wondering what is a good setting that would be equivelent to 'quickest' on other satnav software. :)
I've found this an issue with every sat nav I've used, is a PITA being taken an extra 30 miles to save 2 minutes.
I tend to just stick with fastest but if i'm doing a longer journey I'll check it on Google maps which gives a range of routes and then add a "via" on my satnav to get it to use the same one if need be.
