Spook said:Took advantage of the "This week only" offer. Arrived yesterday after preliminary testing im very happy. Theres a small amount of bleed in the corners but it is not noticible in normal use and Im hoping it will disappear after a few days.
JonC said:OK, well I ordered and received one of these yesterday, and it appears to be suffering from the buzzing issue.
In standby it gives out a (quite quiet) high pitched whine, and in regular use it gives a buzz/rattle, in both cases it emanates from the part of the screen that takes the AC in. It's not really load, but it's load enough to hear and be annoying when I've not got the sound turned on with my computer.
Where do I stand on getting a replacement?
rezza said:How do you check for bleed. I mean when is it visible and when its not. I got mine today and I am still doing some tests. No dead pixels though.
Well I discovered that with LCDs you WANT ambient light present when using the monitor (unlike a CRT which can get washed out with nearby lighting) Anyhow this made the black levels much nicer looking.. I must say the overall image quality on this LCD is outstanding. Now we just need NEC to make a 24" version![]()
nec 20wgx power button issues, anyone else had issues with this, and how did you solve them
cheers
