NEC MultiSync 2080UX + to 24"
27 May 2008
Hello,
At work I have the monitor named in the thread's title and I'm wondering if anyone knows what panel technology it is. Everything is fine with it for the 10 months that I have been using to do just about anything. Therefore, since I'm currently in pursuit of a 24" monitor I'll be going for one that features the same panel, basing on the experience I'm having with NEC one :) Thanks in advance!
Can't seem to find that exact model on the NEC website, there's a 2070 which is TN and a 2090 which is S-IPS.
Quick way to check if it's a TN, look from an extreme vertical angle (top down and then bottom up), if the image seems to become a "negative" (like when getting film developed) it's a TN. If there is no perceptible change when looking at extreme vertical and horizontal angles it's an S-IPS.
Your only option at 24" (short of importing an NEC 24" WUXI from the states and foregoing a warranty) is currently the Hazro HZ24W which is having an updated model launching this month.
