- 23 Jan 2008
hi im trying to set me sound up on me gaming pc to come out the monitor speakers and me other speakers as well how can i set this up? thanks
i couldnt be bothered to look at mine before, but i have looked now, its next to the vga port
do you think its not worth doing it then?why dont you use the monitor as the front left and right, and your other speakers for rear left and right, for a sort of surround sound effect. (the speakers on the monitor are prity to poor to be honest, probably worst bit of the screen, they arent very loud at all.)
edit:- i think there are 2 sockets underneath there, you have it plugged in the correct one??
ive got the monitor and my speakers plug in to the same jack with a splitter but can't get audio on me monitor? the audio on monitor is at 100% but not geting any thing.
ive got sound throw me speakers just not the monitor onesthink you might need to go into the menu, and go sounds, then audio select.
any one???also does any body know how to set the pc up with HDMI ive set it in the OS but till it gets in the OS it gos to DVI and ive got 3 OS so i haf to go to DVI then go to HDMI wen in OS does any one know how to set it up so that it just gos to HDMI?
hi mate ive tryed that but no signal till it gets to the OSumm turn pc off, discon dvi/vga or whatever, plug in hdmi into pc and monitor, turn on pc, should do all the work for you???
