need 9cm fan
I got the Silverstone FN91, quiet and push decent cfm (its rated at 26 dBa/36,89cfm), quite cheap too (about 2 quid something) :p
well the best ive seen so far is the noiseblocker se2 which is 37cfm @ 22db.
gonna do some more looking around but looks like the noiseblocker is the one i will be going for.
Is this for your hr-03 cyber? Thought you were running a 120mm on it?
I was using a Zalman 92mm attached to a fanmate, can be run as quiet as you want.
Cyber-Mav said:
im after a good 9cm fan thats not loud but still shifts a lot of air. any ideas on what would be best for me?
James Gorbold/Custom PC said:
We also tested the 92mm Akasa Amber fan, which is purported to move 29cfm of air at 18dBA at its fixed speed of 1,400rpm. In our tests, the 92mm Amber produced a respectable 24.1dBA of noise and 25cfm of airflow, which makes it one of the most efficient 92mm fans available, and definitely worth checking out.
Akasa AK-184-L2B Amber Ultra Quiet
92mm Fan - 3 pin
£6.46 inc VAT here
