need a a guide to 360 towel trick...
I heard when you send your XBOX off to MS all they do is the towel trick...is this true?
Not sure whether you're taking the mickey or not :p
Under the assumption that you aren't, no, MS don't do the towel trick, they typically just replace the motherboard if it's RROD/E74.
